by matt89glturbo » Fri Dec 31, 2010 1:57 am
These are the best pics I have of mine, it's the steeper runner design, but if I understand it, there are 2 versions of VICS, and mine is the dumber of the 2...so some of them have a feed for the chamber above the VICS valves (like inside the gasket)
Either way...was off a low CR '88 auto engine...not sure if it was wagon or AWD or anything, but pretty good I think that I could pick out the year on one I imported to America, and the flex was still bolted to it, so def an auto...
so yeah, is there a way to move this to the intake thread? had them both open in diff tabs, and ended up in the wrong one...
- Attachments
- inside the chamber in the upper plenum
- upper chamber.jpg (33.46 KiB) Viewed 43366 times
- looking down at the vics valves and runners
- runner top.jpg (40.48 KiB) Viewed 43366 times
- with the gasket set in place
- gasket installed.jpg (39.54 KiB) Viewed 43366 times
