 by Fred » Tue Mar 08, 2011 3:13 am
			Brandon, you wouldn't, do NOT do that, your turbo will NOT like it. Link ECUs are common in NZ, because they are from here. FreeEMS will change that, though.
low n slow, move your oil feed to the block there is not sufficient pressure in the head to supply the turbo properly...
The turbo will not last well like that.
