[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
FE-DOHC.org • View topic - Coolant Flow And Head Gasket Design
All about the double over head cam head that we all love!
Postby Fred » Mon Dec 13, 2010 7:37 am
The designs vary and the only good way to route coolant is from front of block to back of head with the correct gasket. Doing it the kia way is bad, just like the stock trucks and miatas/mx5s.
More info/pics required.
Re: Coolant Flow And Head Gasket Design
Postby FE3TMX5? » Sun Mar 06, 2011 10:58 pm
http://i165.photobucket.com/albums/u65/ ... 095623.jpg
this is the coolant hose i bought and will be using for fe3 in rwd application, just need to source out the Thermostat piece with sensor that points towards im instead of exhaust.
20.75$ cdn
its off a 2007 yukon sierra, upper rad hose.
FE3TMX5?
Postby d0zxmustang » Sun Aug 25, 2013 5:24 am
European parts houses stock FWD design head gaskets. If you get a head gasket kit by Payen (a cousin of federal-mogul), it is virtually a Mazda kit. Every detail in gaskets down to valve seals are identical to factory Mazda. Excellent quality.
For installs in Mazda GD chassis, a radiator hose from a mid 90's Toyota 3.0 cars works great with a slight trim in straight length.
d0zxmustang
Postby jesiotrot » Sun Aug 25, 2013 6:13 am
Also in a GD chassis if you're in Australia you can use a top radiator hose from a Mitsubishi Magna.
And the heater hose that goes from the head to the core, you can use a heater hose from a Holden straight 6 engine, VB/VC/VK ones work, its a straight hose with a short 90 degree section at one end, so just trim it to the right length. The size is spot on.
jesiotrot
Postby Fred » Sun Aug 25, 2013 1:18 pm
Postby d0zxmustang » Mon Aug 26, 2013 1:39 am
I use rockauto.com.
d0zxmustang
Postby Fred » Mon Aug 26, 2013 10:47 am
So it's the Payen BR850 for just the HG and DR850 for the top end kit, right. It quotes me prices in euros, likely with VAT, I assume a US based browser would see USD prices with less tax. 30 euro for the HG and 53 for the top end kit.
Postby d0zxmustang » Thu Aug 29, 2013 12:34 am
That is correct Fred.
d0zxmustang
Return to Top End
Users browsing this forum: No registered users and 0 guests
