FE-DOHC.org • View topic - OEM General Accessory Variants
Postby Fred » Sat Nov 27, 2010 3:59 am
Oil coolers/heat exchangers none/thick and round, any smaller ones stock on the dohc engines?
Alternators - all the same?
Starters - standard or gear reduction
Knock sensors - yes or no
Distributors - square plug or round
What else?
OEM General Accessory Variants - Alternator #1
Postby Toyama Racing Spirit » Wed Sep 07, 2011 1:39 pm
Platform: High compression FE DOHC motor + oem bearing bracing.
Alternator: This may come in handy if you ever decide to replace your existing one.
* Manufacturer: Mitsubishi
* Mounting points, top and the two at the bottom, width apart in mm and distance apart from bottom to top mount (taken from center of bolt holes)
180mm top to bottom spacing, 110mm outer width for the lower bracket, 83mm inner width of the same bracket
* The pully diameter and width
62.5mm outer dia. 15.5mm width (outer), 9.5mm width (inner and belt size is the same)
* The stock output: 55A @ 12v
Our online store -
Dealers for AEM Electronics | Injector Dynamics | T1 Race Development | Zenky Racing | PowerBrake | Pauter Rods
www.jdmimport.co.za - For the love of Japanese performance vehicles
Location: Johannesburg, South Africa / Tokyo CBD, Japan
Users browsing this forum: No registered users and 2 guests
