Comprehensive info on Nissan brakes: http://nissans15.com/brakes.htm
Compared to the RS/RZ RX7 FD3S 314x32 which would be good if they fit over the target wheels (fd stock or r32 gtst/gtr stock)
Nissan have:
R33 GTS-T RB25DET powered cars had 296x30 but 32mm will fit in it, nice.
R34 GTT RB25DET powered cars had 310x30, unsure about 32 fitting or not.
R32 GTR have 296x32
Any of the above suit me. The guy claims stock calipers are used up to 324mm modded.
Stageas got small crappy brakes, apparently.
Most of these Nissans use exactly 1 inch bore masters. Some a bit bigger, some a bit smaller. I bet mine is tiny compared to that. I wonder if the one I intend to use is big enough. Yes, it's 1" too:
http://www.rx7.org/Robinette/mastercylinder929.htm
If I can get a fresher and lower diameter booster, that'd be good, too. Apparently the booster is dual diaphragm. What that means in practical terms I have no idea. I could do with some more clearance to the intake, though. In future I want to add staged injection.
