My current plan is to get a pair of FD RX7 front calipers from the harder-core variant with the 314x32mm rotors. On top of that, I'll also need to get the rotors, and have some new hubs turned up out of chromoly or something like that.
The calipers I'm planning to pick up look like this:
"The Type RS had a brake upgrade by increasing rotor diameter front and rear to 314 mm (12.4 in) and front rotor thickness from 22 mm (0.9 in) to 32 mm (1.3 in)."
Rotors for these cars seem harder than normal to find? DBA don't list anything as far as I can tell.
The rear axle I have is from a bongo friendee van and has decent sized rotors on it. I really need to pick up a set of rims first so I can ensure the diff is the right width and new tyres/wheels will clear chassis and edge of deck.
