Mazda Rustler FE-DOHC Turbo
Build threads and compulsory matching comments threads. All threads, in pairs, should be linked from the users sig so that replying is easy. Only the owner is allowed to post in their build thread, all others must post in the comments thread.
Postby EmileS » Wed Dec 21, 2011 5:53 pm
This was a project I started in January 2011, unfortunately I lost control of it after the dyno tune and put it into a tree, spent a month in hospital. I have since scrapped the FWD Rustler and bought a RWD Nissan 1400 "Bakkie" (South African term for pickup truck)
Specs for the Rustler:
2.0 FE-DOHC Aluminim Sump 10:1 Compression Motor, stock internals.
FE5A Intake and Exhaust Cams
T66 Ball Bearing Turbo
Tilton Tripple Plate Clutch
Billet Steel Flywheel
ARP Flywheel Bolt
60-2 Crank Trigger Set Up
4 X 1600cc Injectors
3 Inline 8 Bar Fuel Pumps
Mazda 12V Turbo Transmission, H-Type
2000HP Charge Cooler
76mm Boost Pipes
Initial tune 26 PSI Boost, 24 degrees timing, 7000 RPM, pistons broke ring lands, power was around 300wKW. Fitted a new set of standard pistons turned the boost down to 22 PSI and made 277wKW. Fuel being used was E85.
EmileS
Re: Mazda Rustler FE-DOHC Turbo
Postby EmileS » Wed Dec 21, 2011 5:57 pm
Picture and specs of the new build:
Nissan B140 LDV
Jeep Grand Cherokee rear diff, 3.72 ratio, LSD
Jeep Grand Cherokee 305mm disks brakes all round
Toyota Cresida 21R Gearbox
EmileS
Postby Fred » Tue May 08, 2012 1:23 pm
Cool truck(s) :-)
Return to Build Threads
Users browsing this forum: No registered users and 2 guests
