FE-DOHC.org • View topic - Fred's Engine Swap Diary
Re: Fred's Engine Swap Diary
Postby Fred » Sun Nov 30, 2014 8:10 am
Spent about 5 hours today working on lowering the crane and stabilising the engine stand, too. Got the brackets for the rear wheels welded on and bolted up. 70 or 80mm lower! Down from about 180mm at the under-car end to about 115mm once I'm done. Should clear the bottom of the ute OK like this. Going to order some steel tomorrow to finish the job tomorrow night. Maybe I can pull the block tomorrow night,or tuesday night.
Pic of shitty low quality welds: https://twitter.com/FredCookeNZ/status/ ... 1268454400
Also added a stud for the handle to rest on when it's stowed. OEM setup simply didn't work at all.
Postby Fred » Wed Dec 03, 2014 6:56 pm
Finished the crane lowering job last night! About one hour spent after a couple of glasses of wine. The engine crane is now in the weeds and ready to rumble! :-D
Pics:
https://twitter.com/FredCookeNZ/status/ ... 4695211008
https://twitter.com/FredCookeNZ/status/ ... 3023367168
May get started pulling the block tonight, or not, we'll see.
Postby Fred » Sat Dec 06, 2014 10:56 am
Postby Fred » Sun Dec 07, 2014 9:56 am
https://twitter.com/FredCookeNZ/status/ ... 6611896320
Maybe an hour and a half, due to high overheads/difficulty of environment, etc.
Postby Fred » Tue Dec 09, 2014 10:32 am
45 mins tonight and I cut this thickwalled pipe in two places, and welded it on, put away the tools, etc. https://twitter.com/FredCookeNZ/status/ ... 0586656769
Postby Fred » Sat Dec 13, 2014 11:10 am
Postby Fred » Tue Dec 16, 2014 9:35 am
Today I went and bought some standard spark plugs, and ordered some BKR7EIX-11 iridiums for after the rough tune is done. An hour all up, including driving there and back.
No ute work tomorrow, and maybe for a few more days due to surgery and side effects thereof. Wish me luck.
Postby Fred » Fri Dec 19, 2014 3:39 am
Postby Fred » Mon Jan 05, 2015 9:51 pm
Postby Fred » Mon Jan 19, 2015 10:57 am
Sunday some stuff got done:
Sorted out the hydraulic clutch setup, rebuilt slave, installed new hose, modified existing hard line, etc.
Dropped new engine into the hole and bolted it up to the gearbox and mounts!
https://twitter.com/FredCookeNZ/status/ ... 0270042112
https://twitter.com/FredCookeNZ/status/ ... 0030825472
https://twitter.com/FredCookeNZ/status/ ... 0618429440
FB IMs with Mike for time spent, but basically all day.
Today, Monday:
Obtained a clutch master push rod and partially modified it. more to come. Call it 2 hours.
PreviousNext
Users browsing this forum: No registered users and 2 guests
