Got a fair bit of that done!
Backed up firmware from the hotel and replaced with truck fw from build server
Turbo, ex mani, main coolant pipe, turbo bracket, down pipe, turbo to IC pipe, oil feed, oil drain, all done.
Sway bar end links replaced with fresh ones from SCA.
Truck pulled out, turned around, wheels cleaned, washed and driven back in. Got into THIRD gear... using the starter motor!
Dip stick tube bent to fit gear.
Oil cooler water connections setup.
Radiator washed and flushed out!
Adaptor loom completed by Mike! <3
Pending:
Need to swap CAS plug. Wiring is stripped, but not done yet.
Need to hook up heater core after CAS is plugged in.
Need to tighten vband clamp on downpipe with deep reach 1/4" 11mm socket. Buy this.
Need to tighten the bell housing bolt that was waiting for turbo install.
Fuel system and inlet manifold not done.
Block braces not done.
Radiator not installed.
New vacuum lines.
Wastegate not installed.
Adaptor not verified as correct. Firmware vs wiring pin out not checked to match.
Need to recallibrate firmware for new hardware (MAP sensor especially)
