FE-DOHC.org • View topic - Fred's Engine Swap Diary
Postby Fred » Fri Jul 04, 2014 7:21 am
This thread is simply a place to record what I get done, and when, so I have a record of it. Follow along toward the eventual videos of glorious FE3 burnouts, etc.
The first step in this thread should really have been "get ute out of storage" which I did some weeks ago. I did nothing since then.... until tonight! One post per working session. This one counts for "get out of storage".
Re: Fred's Engine Swap Diary
Postby Fred » Fri Jul 04, 2014 7:28 am
Postby Fred » Sun Jul 13, 2014 6:50 am
Postby Fred » Mon Jul 14, 2014 6:08 am
Postby Fred » Tue Jul 15, 2014 4:23 am
Postby Fred » Wed Jul 16, 2014 10:32 am
Postby Fred » Thu Jul 17, 2014 6:11 am
Postby Fred » Fri Jul 18, 2014 6:46 am
Postby Fred » Sat Jul 19, 2014 3:16 am
Postby Fred » Sun Jul 20, 2014 9:55 am
Spent 15 minutes outside today, undid one clutch slave cylinder bolt with my new gearwrench 12mm ratchet ring, and tried to suck the #1 piston out with a vacuum cleaner! Not worth writing about, cept that I said I would.
Other than that, I drove across town and picked up the FreeEMS ECU kit that's going to run it! :-) < real progress.
Tomorrow probably consists of cleaning the block deck more. And searching for a special nut that I need to pull the oil filter tube out.
Next
Users browsing this forum: No registered users and 69 guests
