FE-DOHC.org • View topic - Mk1 Ford Escort with FE-DOHC-Turbo
Build threads and compulsory matching comments threads. All threads, in pairs, should be linked from the users sig so that replying is easy. Only the owner is allowed to post in their build thread, all others must post in the comments thread.
Postby low'n'slow » Mon Nov 29, 2010 8:37 am
DROVE HER FOR THE FIST TIME THIS WEEKEND . . . . SEE VID >>>>
Painted the trailer :thumbright:
low'n'slow
Re: Mk1 Ford Escort with FE-DOHC-Turbo
Postby FE3TMX5? » Sun Mar 06, 2011 11:03 pm
what a wicked build nice car man!
do you have more pics of the turbo manifold, and how well it clears everything?
FE3TMX5?
Postby low'n'slow » Mon Mar 07, 2011 7:44 am
Sorry missed your question.
low'n'slow
Postby low'n'slow » Mon Mar 07, 2011 7:47 am
Dimensions of sump for fitment in an escort ... all depends on your engine mounts you make i guess so probably not allot of use to anyone.
Adding a pipe to the side of the sump for the turbo's oil return
Standard oil pickup on the right modified on the left
Everything back together
low'n'slow
Postby FE3TMX5? » Mon Mar 07, 2011 2:31 pm
thanks for all the pictures, it appears you have the hybrid dist/cas from a miata, and a fm link ecu to run your car.
im curious as to why you pull oil from your head for the oil feed line opposed to the back of the block like stock on the f2t
Brandon
ps did you buy or have that manifold made, or build it yourself.
FE3TMX5?
Postby Fred » Tue Mar 08, 2011 3:13 am
Brandon, you wouldn't, do NOT do that, your turbo will NOT like it. Link ECUs are common in NZ, because they are from here. FreeEMS will change that, though.
low n slow, move your oil feed to the block there is not sufficient pressure in the head to supply the turbo properly...
The turbo will not last well like that.
Postby Sondre » Tue Aug 27, 2013 7:09 am
Wicked build, would really like to have something like that! Do you have a idea of the weight of it? Sub900kg?
One more thing, what is the best place to get the oil-feed from, for the turbo on our motors?
Sondre
Postby Fred » Tue Aug 27, 2013 11:54 am
Always take the oil from the block, not the head. The head has lower pressure due to the restrictor pressed into the block. Journal turbos require pressure and should never be used with any restricted feed.
Return to Build Threads
Users browsing this forum: No registered users and 3 guests
