Re: Head Bolt vs. ARP Stud Analysis/Discussion
Posted:
Mon Jul 20, 2015 11:50 am
by Fred
A few other ARP links for consideration:
Torque figures:
http://arpinstructions.com/generaltorque.htmlAssembly lube:
http://arp-bolts.com/kits/ARPkit-detail.php?RecordID=89 (part number 100-9911 for the 20oz bottle)
MLS instructions by gaskets-to-go:
http://gasketstogo.com/PDF%20files/MLS% ... ctions.pdfFred.
Posted:
Tue Jul 21, 2015 11:00 am
by Fred
So, latest from ARP on this is that the stud part number that monoxidechild provided was totally wrong with 1.25mm thread pitch on both ends! Utter fail.
I've filled out the spreadsheet form for stud finding and submitted it for analysis by ARP, we'll see what they come back with.
Posted:
Tue Jul 28, 2015 10:38 am
by Fred
The longer stud that I mentioned above is incorrectly listed on Summit's site as being 8740 steel, when it's actually "ARP2000".
The undercut on this is 11.278mm, 0.278mm more than the Mazda bolt shank. In contrast, the part in use by quite a few FE3 owners is undercut to a very-thin 10.414mm. IE, 0.586mm less than the stock Mazda bolt shank! No wonder Alan doesn't recommend them for high cylinder pressure applications!!!
I'm going to investigate having some precision spacers made up to use the longer stronger studs and bigger more appropriate nuts/washers.
Posted:
Sun Sep 27, 2015 9:50 am
by Fred
Order placed!
Need to hit up the head gasket man next. Then it's down to the garage to clean the bottom end out and start putting it all back together
Posted:
Mon Sep 28, 2015 7:06 am
by Fred
Diary of the preparation after previous failure, and installation once the gear all arrives and I have everything ready for it!
viewtopic.php?f=10&t=723
